Date/Time: Sat, 01 Feb 2025 02:06:27 +0000
Problem with real time quote
View Count: 605
[2019-06-14 16:22:43] |
User182617 - Posts: 3 |
I don't have problem with the data on the DOM.My problem is that the data on the sierra chart .Although I'm connecting to a live server the data don't run according to the data on the DOM or they don't run at all.
[2019-06-14 18:19:38] |
Could you first please refer to help topic 3.4 here to see if you are receiving data from the data feed: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.4 - Not Receiving Real-Time Data From Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
