Date/Time: Wed, 27 Nov 2024 04:51:09 +0000
Commissions
View Count: 2166
[2013-11-27 22:18:50] |
100 - Posts: 147 |
I am trying to add a commission calculation to the P/L system in SC. I seem to ONLY be able to add it in the trade activity log. Shouldn't there be another way to see commissions, outside of that log? Moreover, in the trade activity log, The addition of a commission only changes the efficiency measurements. Why isn't there a way to add the commission costs into the immediate and/or cumulative P/L calculation? Does SC have any plans for adding a more logical system? Date Time Of Last Edit: 2013-11-27 23:23:35
[2014-07-28 20:58:57] |
User40526 - Posts: 166 |
has this been answered? Commissions are not figured in my P&L on the Trade Activity Log even though I have "Use Commission" checked.
[2014-07-28 21:08:31] |
Shouldn't there be another way to see commissions, outside of that log? Why isn't there a way to add the commission costs into the immediate and/or cumulative P/L calculation? For instructions on using the Use Commission setting, refer to: https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#Controls Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-28 21:08:47
