Date/Time: Sat, 01 Feb 2025 02:10:26 +0000
[Programming Help] - how to connect to okex
View Count: 686
[2019-06-14 08:47:32] |
ershidu - Posts: 4 |
hello, I want to connect to okex I can code to connect okex(https\socket) but I don't know how to integrate into Sierra chart by DTC Can anyone help me thanks |
[2019-06-14 18:28:04] |
This is a more advanced programming subject. We can only refer you to the relevant documentation here: Data and Trading Communications (DTC) Protocol Test Client Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
