Date/Time: Sat, 01 Feb 2025 01:46:03 +0000
Hide Fields in Trade activity logs
View Count: 658
[2019-06-13 17:24:41] |
Chippstrader - Posts: 30 |
Hi, I would like to know if any way to hide/remove difedls in Trade Activity logs in Trades Tab. Plase see screenshot |
TALscreenshot.jpg / V - Attached On 2019-06-13 17:24:00 UTC - Size: 131.69 KB - 261 views |
[2019-06-13 18:22:09] |
The only option is to minimize the width of a particular field by grabbing the right edge of the column where the label is, and then dragging to the left. Refer to the information here for how to change the size: Trade Activity Log: Column Widths and Font Once you do that you can drag the field over to the rightmost side. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
