Date/Time: Sat, 01 Feb 2025 01:52:02 +0000
ACSIL - Trade > Trading Keyboard Shortcuts Enabled
View Count: 731
[2019-06-13 13:54:53] |
User462086 - Posts: 196 |
Hi, is there a way to detect, or better yet, set, the current state of this option from within an ACSIL custom study? I want to use standard shortcuts regardless of whether the target is Sierra Chart or a custom study. Many thanks!! |
[2019-06-16 02:17:02] |
We will add new ACSIL functions to get and set the trading keyboard shortcut's enable state.
[2019-06-16 06:01:30] |
that would be really great, thank you!!
