Date/Time: Sat, 01 Feb 2025 01:52:31 +0000
P&L on chart not reflecting commissions, version 1928
View Count: 1109
[2019-06-13 13:53:29] |
User104854 - Posts: 457 |
I just updated to this version from 1864 and my charts no longer reflect the commissions in the P&L calculation. I've gone into symbol settings and made sure the commission rate is correct. The commissions are reflected in the trade activity log so that's not an issue. I've also checked 'Use symbol commission setting in trade list and stats calculations' under advanced settings 3. This was working fine in the previous version. What do I need to do to fix it? |
[2019-06-13 15:50:55] |
This has been verified to work correctly. Double check the commission is set for the correct symbol pattern in the Global Symbol Settings. Refer to: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) And then after that select Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
