Date/Time: Sat, 01 Feb 2025 02:09:30 +0000
Features of working with OCO
View Count: 682
[2019-06-13 07:16:40]
User221057 - Posts: 12
Good afternoon.
How to solve the problem.I have an OCO,I wanted to close the Sierra Chart at the same time ends the trading day.An inscription appears in the terminal "If these open order include client-side managed Attached order or Trailing Stop order,they will no longer be managed".What should I do to save Take-profit order and Stop order in the terminal?(That I would open the terminal and rearrange these orders)
[2019-06-13 18:00:57]
They are going to be saved. However, make sure you have this option enabled:
Global Trade Settings Windows: Use Server Side OCO Orders (if supported) (Global Settings >> General Trade Settings >> General) (Use server-side OCO)
If you are using the Sierra Chart order routing service:
Sierra Chart / Trading Technologies Futures Order Routing Service
You can then use this setting where the orders are held on the server if the parent order has not yet filled:
Global Trade Settings Windows: Use Server Side Bracket Orders (if supported) (Global Settings >> General Trade Settings >> General)
[2019-06-13 18:01:49]
Also, refer to the information here for how attached OCO orders are handled with respect to when they are managed by your local Sierra Chart system and when they are managed by the server:
Attached Orders: General Management of Attached Orders
And be sure to refer to our prior post above.
