Date/Time: Sun, 24 Nov 2024 19:32:24 +0000
Tool Bar
View Count: 1318
[2013-11-27 19:52:04] |
tellerbe - Posts: 109 |
My tool bar disappeared. It's still listed under studies but disappeared from my screen. How do I get it ba,k? TE |
[2013-11-29 06:57:15] |
Please refer to the documentation here for help with this: https://www.sierrachart.com/index.php?l=doc/doc_WindowMenu.html#ToolBar Refer to this subsection: Unable to Make ToolBar Visible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-30 19:26:24] |
Solution 1. I have HKEY_Current_User. There is no: "Software\Sierra Chart\SierraChart" that follows. Solution 2. I have no such file in the list. TE |
[2013-12-01 20:43:07] |
Make sure there is a checkmark by Window >> ToolBars >> ToolBar [1-8] on the menu for the ToolBar that you want.
