Date/Time: Fri, 31 Jan 2025 22:55:19 +0000
Technical studies betwee 2 charts
View Count: 688
[2019-06-12 17:27:25] |
User283207 - Posts: 5 |
Is there a way to have a Slow Stochastic study from a 15 minute ES chart be visible on a 7,500 volume ES chart? I would like to plot the 15 minute slow stochastic on the 7,500 so I do not have to keep looking at both charts
[2019-06-12 18:57:40] |
Yes, this is what the Study/Price Overlay study is for. Refer to the documentation here: Study/Price Overlay Study Just keep in mind that since you are overlaying to a non-time based chart, the study will look a little different, as it is going to match up the data based on the times of the bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
