Date/Time: Fri, 31 Jan 2025 22:59:28 +0000
Sierra Chart user input delay using live data
View Count: 801
[2019-06-12 08:54:54]
User629461 - Posts: 184
Hi, since going to real time streaming data, i find that SC has a problem with delay on user input (eg mouse actions - zoom/scroll/move chart) and hangs for a second or so every few seconds, particularly if the computer restarts from sleep mode. I find i have to Reload & Recalc (Ins key) each chart to get it to behave which shouldn't be necessary. I'm using 1 chartbook with 16 charts (all the same instrument - different timeframes - 1/3 daily & higher, the other 2/3 are intraday and tick), no complex studies (std volume on most and Zig Zag Cum Volume on some charts). When this occurs the CPU fan also kicks to high until I Reload. Is this a known problem? Any advice on resolution, as its very unproductive, particularly if it happens during a trading session. Thanks
[2019-06-12 21:25:24]
In general refer to help topic 30 for this kind of condition:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
And refer to:
Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading
Also this makes no sense at all. That will never be necessary unless you are using some custom study which has a problem.
Date Time Of Last Edit: 2019-06-12 21:26:18
