Date/Time: Fri, 31 Jan 2025 22:45:55 +0000
Does sc.GetTradeStatisticsForSymbol use sc.TradeAndCurrentQuoteSymbol or the chart symbol?
View Count: 836
[2019-06-11 23:16:58] |
User796776 - Posts: 95 |
My chart is using ESM19_FUT_CME with MESM19_FUT_CME as the trade and current quote symbol. When calling sc.GetTradeStatisticsForSymbol, the profit and loss numbers seem to be using the CurrencyValuePerTick for the chart symbol vs sc.TradeAndCurrentQuoteSymbol. Is it my responsibility to perform the conversion? Executing sc.GetTradeStatisticsForSymbol produces the following s_ACSTradeStatistics ClosedProfit 517.41998884826899 double ClosedLoss -3.7899997085332870 double TotalCommission 11.369999125599861 double MaximumRunup 517.41998884826899 double MaximumDrawdown -3.7899997085332870 double MaximumTradeRunup 962.50922428444028 double MaximumTradeDrawdown -275149.99077571556 double MaximumOpenPositionProfit 425.00307476148009 double MaximumOpenPositionLoss -137562.49692523852 double TotalWinningTrades 2 int TotalLosingTrades 1 int TotalLongTrades 3 int TotalShortTrades 0 int TotalWinningQuantity 2.0000000000000000 double TotalLosingQuantity 1.0000000000000000 double TotalFilledQuantity 6.0000000000000000 double LargestTradeQuantity 1.0000000000000000 double LargestWinningTrade 271.20999414473772 double LargestLosingTrade -3.7899997085332870 double TimeInWinningTrades 328 int TimeInLosingTrades 1059 int MaxConsecutiveWinners 2 int MaxConsecutiveLosers 0 int Version 3 int LastTradeProfitLoss -3.7899997085332870 double LastTradeQuantity 1.0000000000000000 double + LastFillDateTime {m_dt=43619.407812800979 } SCDateTime + LastEntryDateTime {m_dt=43619.395556053321 } SCDateTime + LastExitDateTime {m_dt=43619.407812800979 } SCDateTime TotalBuyQuantity 6.0000000000000000 double TotalSellQuantity 0.00000000000000000 double The attached screenshot shows the Statistics Tab from the Trade Activity Log. |
Screen Shot 2019-06-11.png / V - Attached On 2019-06-11 23:13:21 UTC - Size: 45.45 KB - 260 views |
[2019-06-11 23:49:49] |
When calling sc.GetTradeStatisticsForSymbol, the profit and loss numbers seem to be using the CurrencyValuePerTick for the chart symbol vs sc.TradeAndCurrentQuoteSymbol. Is it my responsibility to perform the conversion? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-11 23:50:06
[2019-06-12 00:01:33] |
OK, I will do the conversion. But this really doesn’t make sense, there are no trade statistics for the chart symbol, only stats for the trade symbol should exist. |
