Date/Time: Mon, 14 Sep 2026 08:00:09 +0000
[Programming Help] - Error when compiling
View Count: 1364
| [2019-06-11 18:42:37] |
| grantx - Posts: 244 |
I am trying to call this function from my code: CalculateDailyOHLC();
But I am getting this error message during the compile: The remote build did not succeed. Result:
Grant_Studies.cpp:3:30: fatal error: scstudyfunctions.h: No such file or directory #include "scstudyfunctions.h" ^ compilation terminated. I have included the following in the header: #include "scstudyfunctions.h"
The file does exist. I have checked. Why is it failing? |
| [2019-06-11 20:00:33] |
scstudyfunctions.h SCStudyFunctions.h Ok it is case sensitive, so I changed it to uppercase and now its telling me this: The remote build did not succeed. Result:
/tmp/cc4FILCF.o:Grant_Studies.cpp:(.text+0x5dfd): undefined reference to `CalculateDailyOHLC (s_sc&, int, int, int, int, int, int, SCGraphData&, SCDateTimeArray&, int, float&, float&, float&, float&, float&, int)' collect2: error: ld returned 1 exit status -- End of Build -- 20:59:36 Date Time Of Last Edit: 2019-06-11 20:03:04
| [2019-06-11 20:56:19] |
You also need to include this file in the build: SCStudyFunctions.cpp Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-11 20:56:48
| [2019-06-12 07:31:10] |
I put this in the header: #include "sierrachart.h"
#include "SCStudyFunctions.h" #include "SCStudyFunctions.cpp" And now the error message is back to this; The remote build did not succeed. Result:
In file included from Grant_Studies.cpp:3:0: SCStudyFunctions.cpp:2:30: fatal error: scstudyfunctions.h: No such file or directory #include "scstudyfunctions.h" ^ compilation terminated. -- End of Build -- 08:29:22 |
