Date/Time: Sun, 24 Nov 2024 18:33:25 +0000
[User Discussion] - multiply + difference of volumeS
View Count: 1364
[2013-11-27 19:06:12]
ariknoi - Posts: 31
the difference study can do Price current chart *X - Price from other chart *Y
i would like to do the same but to the volume of the charts (and not the prices b/c i can't select anything else beside the price)
is there is a way to do this?
[2013-11-27 21:06:22]
The current Difference (Bar) study does calculate the volume difference already.
[2013-11-27 21:20:51]
ariknoi - Posts: 31
k
i need to "based on" = volume on the main chart and than the chart #2 number will be based also on volume or is it on price? b/c there is no place to define the 2nd chart's number to use
[2013-11-29 03:16:48]
Create your own custom study to meet your requirements:
http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html
[2013-11-29 05:17:45]
Sawtooth - Posts: 4119
You could use the Study/Price Overlay study, then use the Study Subgraphs Difference study.
