Date/Time: Sat, 01 Feb 2025 13:03:31 +0000
Numbers Bars Errors in Replay Mode
View Count: 1082
[2019-06-11 18:31:38]
skelcap - Posts: 139
Hi, I have noticed that you can get differences in the Numbers Bars when viewing in replay mode. See the attached 2 files for ES futures and compare the bar at 11:08. I am using 1 tick data and the SC Exchange Data Feed. I double-checked the "Original" bars against the underlying .scid data file using my own construction of the numbers bars and they agreed. The "Replayed" bars were generated at 1.0x speed with no jumps, and you can see the 11:08 bar has several differences. Actually I get a different result every time I run the replay. How is this possible?
imageES Numbers Bars - Original.png / V - Attached On 2019-06-11 18:30:55 UTC - Size: 48.18 KB - 271 views
imageES Numbers Bars - Replayed.png / V - Attached On 2019-06-11 18:30:59 UTC - Size: 43.96 KB - 264 views
[2019-06-11 20:12:11]
We do observe this when this option is on:
Chart Settings: Combine Trades into Original Summary Trade (Data Feed and Exchange Specific) (Chart >> Chart Settings >> Chart Data >> Chart Data menu)
We have to see why that is happening. Disable it.
[2019-07-17 21:08:50]
Letting you know this has been resolved about three weeks ago.
