Date/Time: Fri, 31 Jan 2025 22:49:08 +0000
DATA
View Count: 618
[2019-06-11 16:20:31] |
Laurunrun - Posts: 12 |
I felt upset about your software. actually, I have paid for the live feed from 28 May to Jun 28. But I can't use it now. So I connected to IB instead of SC. and I remembered that I paid for USD36, I can use for 2 computers, or am I wrong. |
[2019-06-11 17:28:13] |
You can access the Sierra Chart Exchange Data Feed which you have activated on your Sierra Chart account while using Interactive Brokers. Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices If you need further help let us know. You can use Sierra Chart on two computers at the same time but the data feed can only be used on one of them at a time unless you activate an additional real-time connection. Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Connections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
