Date/Time: Fri, 31 Jan 2025 22:36:27 +0000
Custom DLL has stopped working with the latest Software Update
View Count: 646
[2019-06-11 00:47:20] |
convergence - Posts: 20 |
Our "T Wave" custom DLL has stopped working with the latest software update. So we are using a previous version to continue using SierraChart. Can you please look and see what might be causing the issues? The other custom DLL's still work fine - this latest version just impacts the "T Wave" DLL Thank you, Terry Rodgers |
[2019-06-11 02:15:29] |
See if it is related to what we describe here: Notice: Studies Compiled With Version 1224 And Lower Will Need To Be Recompiled Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
