Date/Time: Fri, 31 Jan 2025 23:02:43 +0000
Window>Tile Vertically
View Count: 1262
[2019-06-11 00:43:20] |
User703334 - Posts: 59 |
Whenever I use this feature or any of the Window>Tile items, the windows that are tiled never expand vertically enough to reach the bottom of the Chartbook. It falls 1/2" short and I have to manually stretch each window fully down to reach bottom of chartbook. Is there a setting that will automatically allow full window expansion down to the bottom of the Chartbook? Thanks, Mike |
[2019-06-11 01:43:22] |
Are there any minimized windows? If so, this will cause the behavior that you are seeing. So you just need to maximize or restore those minimized windows.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-11 01:46:15
[2019-06-11 12:34:22] |
Yes, there are minimized windows. For example, I'll Window>Tile Vertical 3 windows and have 5 minimized. In this instance, is there anyway to fully expand the Vertically tiled windows to reach the bottom of the chartbook? I understand if I 'close' the 5 remaining untiled windows they will be deleted. Is that correct? |
[2019-06-11 14:37:38] |
We will add an option to allow the space where minimized chart windows are, to be used during a tiling operation. I understand if I 'close' the 5 remaining untiled windows they will be deleted. Is that correct? Yes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-11 14:38:18
