Date/Time: Fri, 31 Jan 2025 22:48:05 +0000
Cumulative Delta
View Count: 803
[2019-06-10 19:16:41] |
User731023 - Posts: 138 |
Is there a Cumulative Delta (Either volume or Up/Down) that you can determine/set number of bars as opposed to just Reset at start of trading day or Reset st Both Session Start Times. For example I want it to calculate from 20 (or whatever) bars back. Thanks |
[2019-06-10 21:50:54] |
You have to modify the existing studies to accomplish this. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-10 21:51:40
