Date/Time: Fri, 31 Jan 2025 22:37:19 +0000
saving chart/dom setups
View Count: 1355
[2019-06-10 16:08:55]
User192647 - Posts: 7
i have my chart / dom setup per [ instructions on the sierra help website ].duplicate chart/ duplicate chart to workbook. my results has proven no good after working for hrs.
i finally found a professional sierra chart user on YouTube video making custom Dom setup that i really like but cannot save per sierra website in the above sentence.
would like to perform a remote access
[2019-06-10 21:16:09]
If you have a chart and/or Trading DOM that is setup as you want it to be, then you can use the Chart >> Duplicate command to duplicate that chart. You should then have the exact same setup using the same symbol as the original chart. You can then change the symbol, or modify as needed from there. It sounds like you already know the link, but here is the documentation for duplicating a chart:
Using Chart Templates: Duplicating Charts / Template Charts
If there is something that is not duplicating as you expect, let us know and we will answer that particular question. If you are having trouble getting the chart or Trading DOM to look like you want, then let us know one of the particular items you are having a problem with.
Date Time Of Last Edit: 2019-06-10 21:16:49
