Date/Time: Fri, 31 Jan 2025 22:39:40 +0000
Combine studies within one region
View Count: 836
[2019-06-10 15:09:53] |
User106601 - Posts: 17 |
would like to combine stochastics and cci within the same region but the scales wont allow both studies to move within the region together, in unison. thankyou |
[2019-06-12 15:46:10] |
Actually if you want them to move together when using the Interactive Scaling functionality they both need to have a Scale Range of Automatic.
