Date/Time: Fri, 31 Jan 2025 22:52:54 +0000
TT order routing ES formatting issues on market replay and some charts
View Count: 741
[2019-06-10 12:19:13]
IconBob - Posts: 61
Before I prepare an in-depth analysis of this issue I thought I would check if there is documentation available that may explain setting up TT order routing formatting. One question I have is which takes precedence in setting formatting options, Chart Settings or TT symbol settings?
[2019-06-10 12:43:04]
There should not be any problem with this at all. Follow the instructions here to apply the Symbol Settings to the chart:
Global Symbol Settings
And also uncheck a Global Settings >> Symbol Settings >>Use Custom Symbol Settings Values.
If there is any issue, just briefly tell us what it is. We do not want anything in-depth. Once again there should be no problem at all.
Date Time Of Last Edit: 2019-06-10 12:43:18
[2019-06-10 15:36:02]
IconBob - Posts: 61
Most of formatting display issues have cleared up. Transition to TT order routing I suspect.
One issue remains with ES symbol formatting when using the Study “Add additional symbol”. ES value is multiplied by 100 i.e. 2875.25 becomes 287525.00
See attachment
imageES FORMAT ERROR 2019-06-10_11-27-37.jpg / V - Attached On 2019-06-10 15:35:15 UTC - Size: 380.3 KB - 335 views
[2019-06-10 16:34:38]
Yes when using Add Additional Symbol you will need to set the Multiplier Input to .01 for this particular symbol.
[2019-06-10 17:57:50]
IconBob - Posts: 61
Using .01 multiplier creates a different problem. Value unstable see attached.
attachmentAdd Addional Symbol Error 2019-06-10_13-51-05.mp4 - Attached On 2019-06-10 17:54:35 UTC - Size: 942.2 KB - 346 views
[2019-06-11 00:08:20]
This problem is now resolved. This will be out in version 1933.
