Date/Time: Fri, 31 Jan 2025 22:39:52 +0000
Chart Issue
View Count: 682
[2019-06-10 09:43:53] |
User371906 - Posts: 141 |
Hello, I have Flex Renko chart with a T3 MA (sloped, Up=green / Red=down) that I use as a anchor chart to overlay on a lower time frame chart as a Background Transparent Region 1 to see the major trend. On my anchor chart (higher time frame), I can see the slope being completely green yet on the lower time frame I overlaid it to there are patches of red which should not be there. Likewise if the anchor T3 is slopping red down there are also zones that are in green that should not be present. http://www.sierrachart.com/image.php?Image=1560159650344.png http://www.sierrachart.com/image.php?Image=1560159367194.png Please let me know. Thank you. Version 1919 |
[2019-06-10 12:55:22] |
All we can say is make sure this Input is set to Yes: Study/Price Overlay Study: Use Colors from Source Study Otherwise, this is just to involved for us to be looking into this specific case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-10 12:55:56
