Date/Time: Fri, 26 Jun 2026 00:10:48 +0000
sc.GetPointOfControlPriceVolumeForBar compile error
View Count: 1604
[2019-06-10 02:39:41]
User189399 - Posts: 51
I try to use sc.GetPointOfControlPriceVolumeForBar() to find the POC price of a bar with code below
int BarIndex
const s_VolumeAtPriceV2 *p_VolumeAtPrice=NULL;
sc.GetPointOfControlPriceVolumeForBar(BarIndex,&p_VolumeAtPrice);
and get the compile error as below:-
error: invalid initialization of non-const reference of type 's_VolumeAtPriceV2&' from an rvalue of type 'const s_VolumeAtPriceV2**'
By referring the link:-
ACSIL Interface Members - Functions: sc.GetPointOfControlPriceVolumeForBar()
It does not provide example how to use this function. Could u provide the example or correct syntax for it?
[2019-06-10 12:45:35]
Make sure you define s_VolumeAtPriceV2 as a const:
Date Time Of Last Edit: 2019-06-10 16:32:12
[2019-06-10 13:47:01]
I have defined const as follows:-
Is it correct?
[2019-06-10 16:36:33]
We apologize we did not have a close look at this. This is how it needs to be:
  s_VolumeAtPriceV2 VolumeAtPrice;
  sc.GetPointOfControlPriceVolumeForBar(BarIndex, VolumeAtPrice);
We will update the documentation with an example.
Date Time Of Last Edit: 2019-06-10 16:37:16
[2019-06-11 01:30:09]
Now it can be successfully complied. However, I want to get the POC price value. I try to get the POC price by
float POCprice;
int BarIndex
POCprice=VolumeAtPrice.PriceInTicks * sc.TickSize;
The =VolumeAtPrice.PriceInTicks value seems incorrect. Do this function return volume of POC only and I should not use it for POC price? If it is inapporiate, any suggestion to achieve my purpose?
[2019-06-11 17:44:56]
There was a problem with this function and has been resolved . We will have a new release out today or tomorrow. And we have also done an additional update to the documentation.
You need to add this line to your code:
sc.MaintainVolumeAtPriceData = 1;
Refer to the updated documentation.
