Date/Time: Fri, 31 Jan 2025 22:51:11 +0000
MAC user
View Count: 2054
[2019-06-10 00:59:33] |
User744156 - Posts: 1 |
I am looking for Mac or web-based platform that will let me place option orders straight from the underlying stock chart. Will Sierra Charts do that? WL |
[2019-06-10 01:32:58] |
Yes it can but you have to specify the specific option symbol ahead of time and it will only be practical to do a market order. Also Sierra Chart does not directly work on the Macintosh but it can be used. Refer to: https://www.sierrachart.com/index.php?page=doc/SoftwareDownload.php#UsingSierraChartOnMacOS Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-10 01:33:52
