Date/Time: Fri, 31 Jan 2025 22:36:10 +0000
Simple Moving Average on 4h XBTUSD not displayed
View Count: 674
[2019-06-09 16:28:17] |
morpheus - Posts: 3 |
Hi, i defined some Charts in Sierra with MAs and EMAs on 4h Chart the MA200 is not displayed. Even the Value for the MA200 is wrong. |
Bildschirmfoto vom 2019-06-09 17-28-35.png / V - Attached On 2019-06-09 16:27:42 UTC - Size: 30.04 KB - 287 views Bildschirmfoto vom 2019-06-09 17-28-13.png / V - Attached On 2019-06-09 16:27:52 UTC - Size: 20.89 KB - 278 views Bildschirmfoto vom 2019-06-09 17-27-52.png / V - Attached On 2019-06-09 16:27:57 UTC - Size: 14.81 KB - 270 views |
[2019-06-09 16:45:46] |
As you see here the Value is 7816. But in Tradingview and other Systems the Value is 7768. |
Bildschirmfoto vom 2019-06-09 18-44-31.png / V - Attached On 2019-06-09 16:44:50 UTC - Size: 13.87 KB - 263 views |
[2019-06-10 01:44:58] |
Refer to: Chart Studies: Resolving Study Not Visible Issue And there is no such thing as a wrong value. The calculations are accurate based on the data in the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
