Date/Time: Fri, 31 Jan 2025 22:42:46 +0000
DOM costume panel
View Count: 994
[2019-06-09 14:56:43] |
User590016 - Posts: 50 |
Hello I came across a video which showed a DOM on the latest release from Sierra with button panels and a layout not related to Sierra. Any idea how to create those buttons? |
DOM_Sierra.png / V - Attached On 2019-06-09 14:56:33 UTC - Size: 349.23 KB - 393 views |
[2019-06-11 00:10:31] |
A Trading DOM can have a Control Bar: Control Bar And you can add many trading related buttons to that control bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
