Date/Time: Thu, 13 Feb 2025 17:02:50 +0000
[User Discussion] - BitMEX data length
View Count: 775
[2019-06-08 18:06:18] |
User116783 - Posts: 84 |
Hi, The earliest my data will go back is March 21st of 2017 (pic of my data settings is attached). Is there a way to back further than this? Preferably as far back as possible. Thanks, ZS Date Time Of Last Edit: 2019-06-08 18:08:50
![]() Attachment Deleted. |
[2019-06-09 02:09:49] |
No, that sounds about right as far as the data available.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-09 02:09:56
[2019-06-09 02:35:27] |
Ok well i just logged into BitMEX's website and the max data I could pull up there went back to 9/01/15. ZS |
[2020-12-19 03:26:45] |
CryptoInfo123 - Posts: 4 |
I can`t have access to data after 2019-may-15 to 2020-jun-15. It never downloads that part. Is it missing or is it some configuration problem in my instance?
[2020-12-19 08:04:44] |
What symbol are you referring to in regards to post #4?
[2020-12-19 21:41:13] |
XBTUSD intraday data on Bitmex.
Date Time Of Last Edit: 2020-12-19 21:41:26
