Date/Time: Sun, 24 Nov 2024 18:50:12 +0000
Moving Average Color Question
View Count: 1858
[2013-11-27 16:34:56]
infpz - Posts: 826
Can you direct me to instructions for this: Is a way to draw a different color between two moving averages to make a channel?
[2013-11-27 20:02:37]
Sawtooth - Posts: 4119
If you can use the Multiple Averages study, instead of two separate MA studies, choose one of the Fill Top/Fill Bottom draw style pairs.
You should be able to use the Study Subgraphs Reference study to do this between two separate MAs, but it seems to have a bug.
Date Time Of Last Edit: 2013-11-27 20:20:29
[2013-11-27 20:03:23]
infpz - Posts: 826
perfect - thx
[2013-11-27 21:51:35]
For this, we recommend using the Moving Averages study which has 3 moving averages. You will only need 2 of the averages. The other one can be set to Hidden.
You can then set 2 of them to use the Top/Bottom Draw Style pairs to fill the area between to study Subgraphs.:
http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#FillingArea
