Date/Time: Sun, 24 Nov 2024 18:49:08 +0000
Study Collection cannot be saved
View Count: 1349
[2013-11-27 15:47:51] |
Sawtooth - Posts: 4119 |
No .StdyCollct file is created when using Save Single or Save All, with or without the '-' suffix. v1054. |
[2013-11-27 16:54:38] |
We see no problem with this. Nothing has changed with the saving of Study Collections. Is there any error message displayed in the Message Log?
[2013-11-27 17:08:43] |
I get this in the Message log: File error when writing study collection file: C:\Users\Tom\Documents\SierraChart DDT\data\Point at all new daily H/L-.StdyCollct | 2013-11-27 10:37:54 This happens on both a win7 and a XP system. The XP system has v1051. I also have a v1019 on the XP box and it works in that version. |
[2013-11-27 17:43:05] |
I installed a separate fresh instance of v1051 and it works. The v1054 where it doesn't work was upgraded from v1051, v1046, v1032. It worked in v1032 before these upgrades. |
[2013-11-29 07:26:11] |
Nothing has changed which would cause a problem. Until we have more reports of this,if any, we do not know what the reason for this is. We do not observe any problem ourselves in testing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-11-29 07:26:22
[2013-11-29 17:18:28] |
OK, this is all from user error. Sorry for the time wasted. I was trying to use an invalid character '/' in the filename. When it didn't warm me, I assumed there was a problem. |
