Date/Time: Sun, 02 Mar 2025 20:43:44 +0000
[Programming Help] - How to normalize a band of ROCs with RSI
View Count: 586
[2019-06-06 17:32:02] |
Tariq - Posts: 16 |
Hi, I have a band of 7 ROCs starting at length of 1 to 7 situated in Region 1. I would like to run an RSI of the Min and Max of the above band. What I did is created a spreadsheet where I calculate the Max and Min in column K and L respectively, which is displayed as a bar in chart Region 3. The problem I have is when I run the RSI on the region 3 it only either picks up column K or L. How do I make them to be treated as one bar with Min and Max value? Please see the example in attached chartbook. Thanks. |
Private File |
