Date/Time: Fri, 31 Jan 2025 22:49:37 +0000
free trial
View Count: 637
[2019-06-06 05:18:28] |
User127223 - Posts: 2 |
Hello, I'm user127223 and its saying my account requires activation. This is my first time using or attempting to use your service. Can you please aid me in gaining the 15 day trial access. Thank you for your time
[2019-06-06 14:33:30] |
John - SC Support - Posts: 37656 |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-06 16:38:11] |
Thank you very much John, you are greatly appreciated! Take care and have a good day man
