Date/Time: Tue, 26 Nov 2024 12:45:37 +0000
How to retrieve saved draft message
View Count: 1036
[2019-06-05 21:40:46]
Tariq - Posts: 16
I just created a new support request but wanted to review it so I saved it as draft. I can't find anywhere how to access it.
Please direct me to the right link or page.
Thanks.
Tariq
[2019-06-06 05:30:33]
We will check on this and get back to you.
[2019-06-06 14:37:22]
John - SC Support - Posts: 36286
Select the option for Start New Support Request from the main Support page, then just above where you enter the support request you should see an arrow followed by the words 1 Draft. Select that arrow to open up the list of drafts that you have saved. Select the one you want and select Load Draft. Then continue to enter your support request as normal.
[2023-11-25 15:57:26]
User92573 - Posts: 530
I can't see anything resembling draft?
[2023-11-27 16:36:40]
User92573:
We do not see any Drafts for your account.
