Date/Time: Fri, 31 Jan 2025 22:49:17 +0000
TWO VERSIONS OPEN
View Count: 621
[2019-06-05 18:28:32]
User28317 - Posts: 149
I HAVE TWO VERSIONS OF SIERRA CHARTS, ONE ON MY DESKTOP FOR LIVE TRADING AND ONE ON MY LAPTOP FOR TESTING, ETC.
DO I NEED TO PAY FOR 2, OR CAN THERE BE A SECOND VERSION IN USE UNDER MY AGREEMENT?
KELLY
[2019-06-05 20:41:26]
Your account is setup to allow for 2 separate installations of Sierra Chart to be running at the same time. So it is not a problem to have both copies running at the same time (no additional fees are necessary).
Keep in mind this is only for the Sierra Chart software. Your data provider may have restrictions on how many active services can be utilized at the same time, which is something you would need to check with them.
