Date/Time: Sun, 13 Sep 2026 06:49:08 +0000
Help with a study that's not working after updating version
View Count: 1311
| [2019-06-05 18:19:46] |
| User66360 - Posts: 81 |
This no long works. It use to work on an older version. Is there something in code you can fix to make it work again. Thanks #include "sierrachart.h" #include "scstudyfunctions.h" #include <math.h> SCDLLName("High Volume At Price") SCSFExport scsf_HighVAP(SCStudyInterfaceRef sc) { SCSubgraphRef MaxVAP = sc.Subgraph[0]; if (sc.SetDefaults) { // During development set this flag to 1, so the DLL can be modified. When development is done, set it to 0 to improve performance. sc.FreeDLL = 0; sc.GraphName = "High Volume At Price"; sc.StudyDescription = "Display high volume at price for each bar."; sc.AutoLoop = 1; sc.GraphRegion = 0; sc.ScaleRangeType = SCALE_SAMEASREGION; sc.MaintainVolumeAtPriceData = 1; MaxVAP.Name = "MaxVAP"; MaxVAP.DrawStyle = DRAWSTYLE_DASH; MaxVAP.LineWidth = 2; MaxVAP.PrimaryColor = COLOR_YELLOW; return; } if ((int)sc.VolumeAtPriceForBars->GetNumberOfBars() < sc.ArraySize) return; unsigned int MaxVolume = 0; float MaxVolumePrice = 0; int Count = sc.VolumeAtPriceForBars->GetSizeAtBarIndex(sc.Index); for (int ElementIndex = 0; ElementIndex < Count; ElementIndex++) { s_VolumeAtPriceV2* p_VolumeAtPriceAtIndex = 0; sc.VolumeAtPriceForBars->GetVAPElementAtIndex(sc.Index, ElementIndex, &p_VolumeAtPriceAtIndex); if (p_VolumeAtPriceAtIndex && p_VolumeAtPriceAtIndex->Volume > MaxVolume) { MaxVolume = p_VolumeAtPriceAtIndex->Volume; MaxVolumePrice = p_VolumeAtPriceAtIndex->PriceInTicks * sc.TickSize; } } MaxVAP[sc.Index] = MaxVolumePrice; } |
| [2019-06-05 18:45:51] |
Has it been recompiled for the current version? Refer to: How to Build an Advanced Custom Study from Source Code The study works for us. It displays these yellow lines: http://www.sierrachart.com/image.php?Image=1559760337563.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-05 18:46:56
| [2019-06-05 18:50:30] |
Can I get a download for the new version? Or instructions on how to get it to work on my charts? I don't understand how to get it to work on my charts? Thank you
| [2019-06-05 23:04:13] |
We can make you a DLL and attach it here.
| [2019-06-05 23:11:00] |
The DLL is attached.
Sierra Chart Support Date Time Of Last Edit: 2019-06-06 00:36:47
| [2019-06-05 23:19:55] |
It just says private file. Where is the attachment?
| [2019-06-06 00:37:09] |
The file has been now made public. By default DLL files are private.
Sierra Chart Support |
| [2019-06-06 11:16:57] |
I have read support boards and cannot get this to load into my data file. Can you please assist? thank you
| [2019-06-06 16:22:20] |
1. You need to save the DLL file to your Data Folder: General Settings Window: Data Files Folder (Global Settings >> General Settings >> Paths >> Files and Folder Paths) Usually this is going to be C:\SierraChart\Data 2. Are you using the 32 or 64 bit version of Sierra Chart? Software Download: Difference Between 32 and 64-bit Versions The DLL was build for the 64 bit version. Sierra Chart Support |
| [2019-06-06 16:32:41] |
i have 64 bit.
| [2019-06-06 17:39:13] |
We are going to set this file to automatically be downloaded when Sierra Chart is restarted. However, we need to know what your Sierra Chart account is . Log into thee support board with Help >> Support Board and post here when that is done.
| [2019-06-06 19:09:43] |
I got it working, Thank you
