Date/Time: Tue, 22 Apr 2025 14:26:37 +0000
Link chart symbols based on chart selection
View Count: 2391
[2019-06-05 18:13:01] |
Eric Uva - Posts: 6 |
I have six charts I watch on a "main/trading time frame". I also have one detached/always on top chart set to a lower time frame. Currently, I have to manually change the symbol on the lower time frame chart to match the main time frame chart. Is there a way to automatically change the symbol on the lower time frame chart when I select a symbol on the main time frame? The Chart Linking options under Chart Settings don't seem to accomplish what I'm looking for. |
[2019-06-06 05:06:46] |
The Chart Linking options should absolutely work for what you want. The only way the Chart Linking would not work is if the charts are in different Chartbooks. Be sure you have the same Link Number for both charts and that the Link Number has the Symbol selected as one of the linking options. Refer to the information here on Chart Linking: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
