Date/Time: Fri, 31 Jan 2025 22:41:39 +0000
version 1928 no commissions calculated
View Count: 1119
[2019-06-05 17:16:06] |
User993067 - Posts: 156 |
updated to 1928...CQG commissions wont calculate in stats..checked all boxes.
[2019-06-06 04:43:35] |
Make sure there is a commission set for the particular symbol pattern or symbol in the Global Symbol Settings: Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
