Date/Time: Fri, 31 Jan 2025 22:55:32 +0000
ASCIL: T&S reconstructed data
View Count: 911
[2019-06-05 16:58:07] |
User590016 - Posts: 50 |
Is it possible to access through coding/ASCIL the combine records exchange summary data from the Times and Sales to allow the developing of custom tools? Like adding another custom study as a new column to the existing Time and Sales Window?
[2019-06-11 16:41:58] |
The source code is not needed for this. We are working on the documentation for this here: ACSIL Programming Concepts: Combining Intraday Chart File Records into Original Summary Trade It will be ready by the end of the day. Also it is not possible to add a new column to the Time and Sales window but you can certainly display data directly on the chart through Study Subgraphs and text. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-11 16:46:19
