Date/Time: Mon, 05 Oct 2026 14:37:23 +0000
Global Profit/Loss Management
View Count: 1336
| [2019-06-05 16:22:31] |
| Sidi - Posts: 2 |
Good day, I have the profit / loss management as shown in the picture. Unfortunately it does not work. can you tell me the mistake? https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=28954 |
| [2019-06-05 18:16:45] |
Refer to the description of the Profit Value After Trigger To Flatten Positions in this section of the documentation: Global Profit/Loss Management: Daily Net Profit Management The Current Net Profit/Loss would have to drop below 250 or lower based on the settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-05 18:17:55
| [2019-06-05 18:53:51] |
From User: Unfortunately, the "trail daily net profit" does not work. Profit Trigger Value: 1000.00 Profit Value After Trigger To Flatten Positions: 250.00 After Trigger When Daily Net Profit Increases By: 500.00 Increase Profit Value After Trigger to Flatten Positions By: 250.00 Max. Daily PL reached: 2219.99 Waiting for P/L < = 250.00 (incorrect!) would have to be like that in my opinion: Waiting for P/L < = 750.00 (correct!) Sierra Chart Support |
| [2019-06-06 19:57:52] |
It does work properly but you are misunderstanding the functionality.
| [2019-06-11 07:30:05] |
| Sidi - Posts: 2 |
could you give me an example so that I can understand it
| [2019-06-13 17:55:13] |
Yes we will provide some further information.
| [2019-06-13 22:21:59] |
| John - SC Support - Posts: 48101 |
We are actually working on some updates to how this works based on what you saw. We will let you know when we have this completed and when it will be released.
| [2019-06-18 17:00:51] |
There has been an update to how the Trail Daily Net Profit works in the latest Pre-Release (v 1936), so it will now function in the way that you were expecting. To update to the latest Pre-Release follow the instructions here: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
