Date/Time: Sun, 24 Nov 2024 19:06:34 +0000
Indicator / alert
View Count: 1233
[2013-11-27 14:58:22] |
User54027 - Posts: 128 |
Hi Guys, Is it possible for me to plot price distance from a moving average. So I could plot for instance how far price is above say the 8ema in relation to the average? Thanks Justin |
[2013-11-27 17:48:29] |
M5amhan - Posts: 468 |
you can use Study Subgraphs Difference study and use Input Study 1: Last & Input Study 2: 8ema
[2013-11-28 05:27:02] |
Yes. Use the Study Subgraphs Difference study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s185 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-28 06:01:21] |
Thanks.....
