Date/Time: Sun, 24 Nov 2024 19:30:32 +0000
References to Other Sheets within a Spreadsheet and different Spreadsheet windows
View Count: 1308
[2013-11-27 14:35:30] |
User61342 - Posts: 2 |
hello i read this on your web site (see below ) now i use References to Other Sheets within a Spreadsheet and different Spreadsheet windows i write in a cell for exemple ='[EUR IND FX.scwbf]IND EUR FX'!$AF$9 it works well you said In approximately July 2013, Sierra Chart will be releasing new high-performance spreadsheet functionality which will not support references between different Spreadsheet windows. but now it works well will you stop this posibility LATER ? because now i would like to create multiple spreadsheet with crossed reference and would like to know if i will be able to use my spreadsheets later with next SIERRA CHART Version thank you ----------------------------------------------------------- References to Other Sheets within a Spreadsheet [link] - [Top] Sierra Chart Spreadsheets support references to cells in other Sheets within the same Spreadsheet window. To reference cells in a particular Sheet in the same Spreadsheet, use the following format. Remember that references are used in formulas and formulas begin with an =. Format: SheetName!CellReference Examples: =Sheet1!A1 References to Other Spreadsheets Windows References between Sheets among different Spreadsheet windows are not officially supported. In approximately July 2013, Sierra Chart will be releasing new high-performance spreadsheet functionality which will not support references between different Spreadsheet windows. |
[2013-12-01 20:48:37] |
We have been delayed with officially releasing the new spreadsheet functionality. The new spreadsheets are in our non-CLR version of Sierra Chart . The new spreadsheets in the non-CLR version do not support references between Spreadsheet windows. Only among the different Sheets within a Spreadsheet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
