Date/Time: Fri, 31 Jan 2025 22:45:17 +0000
What service package should I get yo use the volume profile??
View Count: 947
[2019-06-04 18:19:00]
Santiago Zorrilla - Posts: 2
I have just paid the standard package but I cannot use the Volume Profile study in my account so, if i want to use it what should i buy?
Date Time Of Last Edit: 2019-06-04 18:25:37
[2019-06-04 19:37:25]
You certainly can use the Volume by Price study. Are you referring to using the Draw Volume Profile tool?
[2019-06-05 00:24:06]
Yes, I am talking about that. I do not know if i have to pay something extra.
[2019-06-05 05:03:10]
For the Draw Volume Profile tool you do need the Advanced service package.
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
Date Time Of Last Edit: 2019-06-05 05:03:34
