Date/Time: Fri, 31 Jan 2025 23:02:09 +0000
Replay: Trade Activity HighDuringPosition and LowDuringPosition are blank
View Count: 807
[2019-06-04 15:46:50] |
User796776 - Posts: 95 |
When replaying a chart and creating trades the trade activity stats for HighDuringPosition and LowDuringPosition are blank. Is there setting to enable these during playback? |
[2019-06-04 23:38:51] |
No. There definitely should not be any problem with this. And we definitely do not observe this. More information is here: https://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php#NotesAboutRunupDrawdownMaximumOpenPositionPLEfficiencyFields Make sure you are running the current version of Sierra Chart. Although if it relates to perhaps trading a symbol which is different from the symbol of the chart there could be a problem. We would have to look into that later on but this is definitely nonstandard. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-04 23:39:36
[2019-06-05 02:56:30] |
Running v1926. Yes, actually it does relate to trading a different symbol, I should have mentioned that. The chart is ESM19_FUT_CME with current quote symbol set to MESM19_FUT_CME with use as trade only symbol checked. I am also seeing several stats in the TradeList with abnormal results: FlatToFlat Max Open Loss (T) Max Open Loss (T) Low Price While Open Should I open a new message for the TradeList results? |
[2019-06-05 04:46:06] |
We have determined the problem and this is now resolved. This will be resolved in version 1930.
[2019-06-05 14:29:10] |
Tested on v1930. Follow up question on the trade open, TradeActivity HighDuringPosition and LowDuringPosition show "Infinity", is this intentional? |
Trade Activity.png / V - Attached On 2019-06-05 14:27:07 UTC - Size: 19.04 KB - 273 views |
[2019-06-05 23:05:27] |
We do not observe that and can see no technical reason which can lead to this. Are those order fills which have been recorded when running 1930? Prior to this those values we would expect just to be blank.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-05 23:05:47
[2019-06-06 03:04:08] |
Yes, the order fills were recorded with v1930. I just tested again; replayed and deleted all trade data for the symbol. Attaching screen shot, export of the trade activity log, and the binary log in case they are useful. Date Time Of Last Edit: 2019-06-06 03:07:05
TradeActivityLogExport_2019-06-06.txt - Attached On 2019-06-06 02:50:44 UTC - Size: 1.71 KB - 367 views Private File TradeActivitySS.png / V - Attached On 2019-06-06 03:03:44 UTC - Size: 64.11 KB - 294 views |
[2019-06-06 19:44:57] |
We think we know why this might happen when using market data that requires a price multiplier. This should be resolved in the next release. We made a change to resolve it and cannot reproduce it.
