Date/Time: Mon, 20 May 2024 23:17:53 +0000
Sierra Chart's Order Routing Service with Discount Trading / Ironbeam?
View Count: 1569
[2019-06-04 15:41:12] |
seandunaway - Posts: 214 |
I'm with Discount Trading, clearing via Ironbeam.. am I able to utilize the new Order Routing Service?
[2019-06-05 05:16:09] |
No Ironbeam does not support TT.
[2019-10-21 19:25:30] |
ycomp - Posts: 277 |
just to clarify, is it still true that it doesn't support TT? I ask because at the bottom of the page it shows commissions for TT here https://www.discounttrading.com/commission-rates.html |
[2019-10-21 21:17:40] |
Please contact Iron Beam and find out. If they do you can use this service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
