Date/Time: Fri, 31 Jan 2025 22:35:14 +0000
Rithimc
View Count: 1142
[2019-06-04 02:39:49]
User759953 - Posts: 8
I have one more thing i need to check. I use rithmic data feed. and iam wondering how i can control if the settings are correct for the deeper data feed that they provide?
Thanks in advance!
[2019-06-05 05:07:29]
We are not providing any further support for Rithmic:
https://www.sierrachart.com/index.php?page=doc/Rithmic.php#TechnicalSupportPolicy
There is one setting in Sierra Chart that can be used to limit the display of the number of depth levels. You will find the setting and documentation here:
Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu)
Date Time Of Last Edit: 2019-06-05 05:07:54
[2019-06-05 09:13:00]
What will the cost be for your new data with a deeper data? and that new data that you now are providing are not unfiltred?
[2019-06-05 09:44:39]
Iam an user of Rithmic data before Juni 2019.
What should i have on these settings below to get out the most of the data?
What should i have o; Chart DOM settings:
- Maximum Volume Bar Width Percentage?
- Maximum Depth Levelds Displayed?
- Maximum Bid/Ask Market Depth Pulling/stacking Levels(0=All Levels)
What should i have on; Global Settings > General Setting > General 1:
- Chart Update Interval In Milleseconds:Should i have it as low as possible?
- Quoute Board Update Interval (Millesexonds): Should i have it as low as possible?
And what should i have on; Chart > Chart settings > Advanced settings 3:
- Market Depth Combine Increment in Ticks:
And what should i have on; Global Settings > Data/Trade Service Settings > Data File Management:
- Compress To Data Unit Size? Should i have it as low as possible?
[2019-06-06 05:00:12]
Pricing is here:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Pricing
You also need to add 5 USD to the real-time connection since your account is with AMP. In about a month we will have new packages which include the CME data feed and the overall pricing will be lower.
Yes the data is unfiltered.
[2019-06-06 05:01:49]
In response to post # 4 :
You definitely do not want to set these lower than like 150 ms.
The other settings you just need to set those as you really require. Those are not specific to any particular data feed.
