Date/Time: Fri, 31 Jan 2025 19:59:11 +0000
Time frame in the control bar settings, make it visible and custom time frame (8H)
View Count: 1298
[2019-06-03 21:08:24] |
User364859 - Posts: 26 |
Hello I can't see the the periodical time (5m 10m 15m 30m 1H 4H 8H dayly weekly monthly in teh controll bar. PLease explain it to me exactly, not only a link on your help page, which I don't recognize. Thank you Walter |
[2019-06-04 03:40:04] |
You need to add your own control bar buttons for these time periods as you require. This is documented here: Control Bar: Custom Buttons for Intraday Chart Bar Period (Custom Buttons for Intraday Chart Bar Period) And for daily and higher time frames, refer to: Control Bar: Customize Control Bars >> Control Bar 1-12 (Global Settings) (Customize Control Bars >> Control Bar 1-8) We would not do anything other than refer to the well-written documentation . There is no point restating what it already has. This would be an extremely serious mistake because we may leave something out and not include screenshots. So your request is nonsensical to begin with. If you are not happy with Sierra Chart, then just leave. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-04 03:44:31
