Date/Time: Sun, 24 Nov 2024 18:42:44 +0000
Mini S/P 500 ( ESZ3 )
View Count: 1228
[2013-11-27 13:34:12] |
User69935 - Posts: 3 |
Can you tell my why do all the indices work perfect, but NOT the Mini S&P 500 ( ESZ3) my provider is OEC Thanks Date Time Of Last Edit: 2013-11-27 16:44:46
[2013-11-27 16:44:36] |
Could be that you have reached the 5 symbol limit: http://www.sierrachart.com/index.php?l=doc/openecry.php#Symbols Otherwise, refer to help topic 3 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
