Date/Time: Fri, 31 Jan 2025 20:17:04 +0000
ChartDOM BidOffer Volume Bar, Ghost Quantities (BitMEX)
View Count: 657
[2019-06-03 07:50:38] |
User82853 - Posts: 13 |
Just updated from 1900+ to the latest. I noticed that my ChartDOM had no volume bars, but after inspection, I realized that they were just very tiny. This applies to both the futures and perpetual contracts XBTM19 and XBTUSD. Found out the problem was that there is a ghost quantity around the 0.0 price level. See screenshot. After setting the market depth in the advanced settings to 10 or 20 levels, the ghost quantity is still showing.
screenshot.1559547277.jpg / V - Attached On 2019-06-03 07:48:27 UTC - Size: 77.72 KB - 302 views |
[2019-06-03 18:03:01] |
BitMex is having market depth issues at this time. We did filter out that 0 price value level but there are other issues going on as well with the BitMex market depth data on their side.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-03 18:03:06
