Date/Time: Sun, 24 Nov 2024 18:59:11 +0000
Sierra RT feed symbols limit
View Count: 1208
[2013-11-27 12:47:24]
jbetlach - Posts: 30
One question: do all symbols i.e. from Quote Boards count towards IBKR symbol limits when using Sierra RT feed? If so, this would be big disadvantage compare to using third party feeds (IQFeed).
The problem is not so much apparent with currently offered RT futures feed as there are not that many symbols. However as soon as equities will be part of the Sierra RT feed, we might (will) have a problem with IBKR symbols limit (standard 100 quotes). Would it be somehow possible, that Quote Board will take price quotes from Sierra RT feed (instead from IBKR) and will therefore not count towards IBKR limit?
Thank you
[2013-11-28 07:09:54]
The symbol limits with the Sierra Chart data feed and the Interactive brokers data feed are completely separate from each other.
The Sierra Chart data feed has a 100 symbol limit. Later on we can offer a 200 symbol limit.
When stock data is provided through the Sierra Chart Real-time data feed, we will add the capability to use this data feed when using Interactive Brokers. The Interactive Brokers symbol limit will not apply in this case.
