Date/Time: Sun, 01 Dec 2024 01:01:15 +0000
new FXCM demo account is not connected
View Count: 1054
[2019-06-03 04:38:30] |
User364859 - Posts: 26 |
Hello The new FXCM demo acount is not yet connected. Please check it. attention my Sierra account login: SierraWZ It is still my old account # 01408507 connected Thanks for your help Walter Date Time Of Last Edit: 2019-06-03 17:03:24
[2019-06-03 17:02:16] |
Your current FXCM account identifier is 01051975. That is what you should see. Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
