Date/Time: Fri, 31 Jan 2025 20:58:26 +0000
connexion failed
View Count: 685
[2019-06-02 19:43:56] |
User758506 - Posts: 9 |
hello Could you help me concerning connecton problem. Please find attached the error message I receive hen I try to connect thank you very much https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=28872 |
[2019-06-03 16:15:40] |
Refer to item 4 in this particular section here about this: CQG Trading Platform Service: Common Error Messages your broker will need to help you with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
